News Beefy RTX 4090 Graphics Card Boasts a Five-Fan Cooler Design
Wouldn't it be more efficient to just increase the radiator size and put triple 120 mm or 140 mm fans?
Out of curiosity: what's the most "extreme" air cooled 4090 on the market in terms of radiator and fan size?
I wonder if one day we'll get tech that could recycle the GPU/CPU heat to power up things like fans.
Thermoelectric/Sebek effect modules exist, though using those to power fans means having a 10-20C gradient across the modules to get meaningful power out of them, which means having to run CPUs and GPUs that much hotter. May as well just let the CPU/GPU run that much hotter and use a less powerful fan for the same net cooling at the same net power.
Reactions: dimar
To one up those companies in a way that will also improve cooling, a AIB should make an RTX 4090, with 3-4 fans but instead of the more basic 3000 or so RPM fans, they should use 6000+ RPM fans. it will also allow people to get the sound of a server running at full load.
Decently made heatsinks respond well to brute forcing additional cooling with faster fans, e.g., using the Noctua industrial fans on the NH-D15 to better handle high TDP CPUs, especially with PBO and higher power limits.
They need to do the same with some videocards but take it up another level.
6000RPM? Big Boi servers use 20000+ RPM 40mm fans that draw over 10W a pop!
But that's also just two 110 mm and one 90 mm fan with ~3,5 slot design? Is there no upside in cooling performance by increasing the radiator and fan size from that?
I think most would prefer to make the cooling solution denser and heavier than bigger.
The 4090' and 4080's s barely fit in many cases
You can only go so far before hampering the air flow and increasing noise levels. I would guess there's a reason why the best CPU air coolers are so big, why not GPU? Not to say 4090 isn't a big card but there are people out there with larger than mid-sized pcs that can take in quite a lot.
But probably I'm just old and everyone is just building water cooled PCs nowadays.
