been out of loop a bit need advice on build
brose80
40
hi all,
so i have a amd a8 3850 right now with 8 gb of ram and a gtx560 2gb card. but i am looking to go back to intel and wanted advice on what to get that will boost gaming performance in a new mb and cpu. I have looked at ivybridge and haswell but just don't know which is better for my needs. I do not overclock but want the best bang for my buck. I should have between 500 and 1000 to spend but if i have 1k I also want to upgrade my shoddy case and maybe video card. also i am look only into asus mb since i have had best luck and results with them.
thank you for taking you time to read and maybe respond.
some of games i play at moment. since i am always changing it up when i find something more fun are.
firefall
swtor
tera
gw2
scarlet blade
dragons prophet
rift
aion
more specifics on current build
ga- a75-ud4h gigabyte mb
amd a8 3850 apu
evga geforce 560 gtx 2gb special super clocked
thermaltake v9 black edition case
thermaltake 600 w powersupply
700 somthing gb wd hd sata3 7200 rpm
2tb sata2 seagate hd
lg dvd burner.
2 4gb 1866 ram at 9 9 9 10 28
win7 home prem 64 bit
Well all of the CPUs mentioned so far are overclocking models, look for a CPU without the k at the end of it, the 4670 is probably your best bet. Also if you aren't going to overclock you can look at H grade mobos or Z since Z is for overclocking H might save you a little bit
You could carry over the ram. I would stay with your graphics card for now to keep cost down. Also to note the card you currently have is more then sufficient for the current games you are playing. So it could be as easy as a motherboard cpu upgrade for now and then at a later point picking a gpu. This is what I'd personally do in your case.
I just feel that you should only go for a graphics card upgrade when you feel that its not up to snub.
Also since you play MMO's a SSD would be a god send for you. A Samsung 840 EVO 120 GB would be a good sweet spot for a OS plus a game or two on the SSD. Unless you would be open for a 250 GB EVO drive in which case you could carry probably every game you listed just fine.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($219.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Motherboard: MSI Z87-GD65 Gaming ATX LGA1150 Motherboard ($152.99 @ Newegg)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($89.99 @ Microcenter)
Total: $492.95
(Generated by PCPartPicker 2013-12-20 19:35 EST-0500)
thanks for your replay, but what i should have been more specific about is that i am looking for mb from asus and intel cpu. but if i can afford the case upgrade i want something that may be used for future water cooling to keep noise down while gaming and that I want something that will be a bit future proof.
what i have looked at are
the i5 3570k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
the i5 4670k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899
the gene VI
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131975
the gene IV
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132064
