Hello! I have a question about the fan layout in a build I plan to make soon. I am a beginner, am building a budget gaming PC, and have no idea how to properly layout the fans. The case that I am using is a CORSAIR CARBIDE 100R case, which comes included with one 120mm fan on the back, which I assume is exhaust. I am also buying two CORSAIR Air Series AF120 fans, which I planned to mount on the front as intake.
The motherboard I am using only has two case fan headers, so I am buying a splitter cable for the front AF120 fans.
I can share the rest of the build if necessary, but I would like to know if you think this would be good or decent for air flow in the case. Thank you.
