G georgec200518 Sep 15, 2018 1 0 10 Sep 15, 2018 #1 Is it possible to compact a H110Ds2 with a i5650?
Solution kanewolf Sep 15, 2018 If you are asking if a Gigabyte GA-H110M-DS2 motherboard -- https://www.gigabyte.com/Motherboard/GA-H110M-DS2-rev-10#ov Can be used with an i5-650 CPU, then the answer is NO. That CPU is about 4 generations too old. If you are asking about an i5-6500, then yes it could ... Here is the list of supported CPUs -- https://www.gigabyte.com/Motherboard/GA-H110M-DS2-rev-10#support-cpu
kanewolf Titan Moderator May 29, 2013 38,483 3,737 156,790 Sep 15, 2018 Solution #2 If you are asking if a Gigabyte GA-H110M-DS2 motherboard -- https://www.gigabyte.com/Motherboard/GA-H110M-DS2-rev-10#ov Can be used with an i5-650 CPU, then the answer is NO. That CPU is about 4 generations too old. If you are asking about an i5-6500, then yes it could ... Here is the list of supported CPUs -- https://www.gigabyte.com/Motherboard/GA-H110M-DS2-rev-10#support-cpu Upvote 0 Downvote Solution
