Benchmark drop, low CPU usage on GTX 970
spAde44
Commendable
Nov 7, 2016
I bought a used GTX 970 over the summer.
Original benchmark when I first got it [Heaven]: 2223
Current benchmark: 1314
I was looking at the CPU usage for the latter, and it's only 16% (quite low).
Performance suffers in Fallout 4 and Civ 6 as well. Only getting 40-50fps on medium settings at 1680x1050.
This is after cleaning drivers with DDU and reinstalling most recent.
Any help would be appreciated....
Zotac GTX 970 4GB
i5 - 4460 @3.2Ghz
8GB DDR3 1600MHz
The problem was my Power Setting. I had switched to a custom Remote Desktop setting that borrowed the CPU power management options from Power Saver.
Control Panel > Power Option > Edit Plan Settings > Change Advanced Power Options Setting
[+] Processor Power Management
Minimum processor state: 100% [doesn't mean your CPU burns at 100% all the time, btw]
System Cooling policy: Active [turns the fan on instead of slowing down the processor when things get hot, i.e. gaming!]
Maximum processor state: 100% [Makes sense]
These are the setting from the 'High Performance' default, so just use that.
TL;DR Use the 'High Performance' power default under Control Options > Power Options.
