Was not sure where i could post this but I had questions and man... I find myself on here more and more everyday for my questions. Can i just say thank you all for helping me with all my questions. Most of the time i feel like its a waste for you all to answer them and then I get such timely responses just makes everything easier. So thank you all
I have a couple of questions but I'll stick to the most immediate one.
I downloaded Sisoftware Sandra for Benchmarking.. after a good.. mm 30-40mins I got my results.
To my surprise (not really) I dont actually understand what Im looking at. lol. I guess i expect it to be like.. "Benchmarking for Dummies..." but yeah.. dont understand a thing.
Anyone mind helping me decipher this encrypted message. Those "Error" don't look too good and the "Finished Successfully: No" worries me.
Code:
SiSoftware Sandra
Display
Connection : Local Computer
Processor Arithmetic
Analysing...
Aggregated Score : 106.73GOPS
Result ID : Intel(R) Core(TM) i7-4800MQ CPU @ 2.70GHz (4C 8T 3.69GHz, 3.7GHz IMC, 4x 256kB L2, 6MB L3)
Speed : 3692MHz
Capacity : 8Unit(s)
Power : 200.00W
Finished Successfully : Yes
Processor Multi-Media
Analysing...
Aggregated Score : 221.48MPix/s
Speed : 3692MHz
Capacity : 8Unit(s)
Power : 200.00W
Cryptography
Analysing...
Aggregated Score : 5.777GB/s
Result ID : Intel(R) Core(TM) i7-4800MQ CPU @ 2.70GHz (4C 8T 3.59GHz, 3.6GHz IMC, 4x 256kB L2, 6MB L3)
Speed : 3592MHz
Capacity : 8Unit(s)
Power : 200.00W
Processor Financial Analysis
Analysing...
Aggregated Score : 16.15kOPT/s
Speed : 3592MHz
Capacity : 8Unit(s)
Power : 200.00W
Processor Scientific Analysis
Analysing...
Aggregated Score : 12.60GFLOPS
Speed : 3692MHz
Capacity : 8Unit(s)
Power : 200.00W
.NET Arithmetic
Analysing...
Aggregated Score : 27.66GOPS
Speed : 3692MHz
Capacity : 8Unit(s)
Power : 200.00W
Memory Bandwidth
Analysing...
Aggregated Score : 14.332GB/s
Result ID : Intel Core (Haswell) DRAM Controller (Integrated Graphics); 2x 6GB Kingston MSI16D3LS1KBG4G DDR3 SO-DIMM (1.6GHz 128-bit) PC3-12800 (11-11-11-28 5-39-12-8)
Speed : 1600MHz
Capacity : 12288MB
Power : 9.40W
Cache & Memory Latency
Analysing...
Aggregated Score : 31.5ns
Speed : 1600MHz
Capacity : 12288MB
Power : 9.40W
File System Bandwidth
Analysing...
Aggregated Score : 91.383MB/s
Result ID : HGST HTS721010A9E630 (1TB, SATA600, 2.5", 7200rpm, 32MB Cache) (NTFS, 4kB)
Speed : 7200rpm
Capacity : 1000.21GB
File System I/O
Analysing...
Aggregated Score : 210.6IOPS
Speed : 6000Mbps
Capacity : 1000205MB
GP (GPU/CPU/APU) Processing
Analysing...
Aggregated Score : 441.15MPix/s
Result ID : NVIDIA GeForce GTX880M (1536SP 8C 953MHz/993MHz, 512kB L2, 8GB 5GHz 256-bit) (CUDA)
Speed : 953MHz
Capacity : 8Unit(s)
Power : 100.00W
GP (GPU/CPU/APU) Financial Analysis
Analysing...
Aggregated Score : 505.32kOPT/s
Speed : 953MHz
Capacity : 8Unit(s)
Power : 100.00W
GP (GPU/CPU/APU) Scientific Analysis
Analysing...
Error (339) : CUDA GP Processor : NVIDIA GeForce GTX880M (1536SP 8C 953MHz/993MHz, 512kB L2, 8GB 5GHz 256-bit) : Floating-Point (Normal/Single Precision) : GP(GPU) call failed. Try another interface (e.g. OpenCL/ComputeShader/CUDA/etc.) or update video drivers.
Error (339) : CUDA GP Processor : NVIDIA GeForce GTX880M (1536SP 8C 953MHz/993MHz, 512kB L2, 8GB 5GHz 256-bit) : Floating-Point (High/Double Precision) : GP(GPU) call failed. Try another interface (e.g. OpenCL/ComputeShader/CUDA/etc.) or update video drivers.
Error (339) : OpenCL GP Processor : NVIDIA GeForce GTX880M (1536SP 8C 953MHz/993MHz, 512kB L2, 8GB 5GHz 256-bit) : Floating-Point (Normal/Single Precision) : GP(GPU) call failed. Try another interface (e.g. OpenCL/ComputeShader/CUDA/etc.) or update video drivers.
Error (339) : OpenCL GP Processor : NVIDIA GeForce GTX880M (1536SP 8C 953MHz/993MHz, 512kB L2, 8GB 5GHz 256-bit) : Floating-Point (High/Double Precision) : GP(GPU) call failed. Try another interface (e.g. OpenCL/ComputeShader/CUDA/etc.) or update video drivers.
Error (339) : Compute Shader Processor : 2x NVIDIA GeForce GTX880M (3072SP 16C 953MHz/993MHz, 1MB L2, 15.9GB 5GHz 256-bit) : Floating-Point (Normal/Single Precision) : GP(GPU) call failed. Try another interface (e.g. OpenCL/ComputeShader/CUDA/etc.) or update video dri
Error (339) : Compute Shader Processor : 2x NVIDIA GeForce GTX880M (3072SP 16C 953MHz/993MHz, 1MB L2, 15.9GB 5GHz 256-bit) : Floating-Point (High/Double Precision) : GP(GPU) call failed. Try another interface (e.g. OpenCL/ComputeShader/CUDA/etc.) or update video drive
Error (339) : Compute Shader Processor : NVIDIA GeForce GTX880M (1536SP 8C 953MHz/993MHz, 512kB L2, 8GB 5GHz 256-bit) : Floating-Point (Normal/Single Precision) : GP(GPU) call failed. Try another interface (e.g. OpenCL/ComputeShader/CUDA/etc.) or update video drivers.
Error (339) : Compute Shader Processor : NVIDIA GeForce GTX880M (1536SP 8C 953MHz/993MHz, 512kB L2, 8GB 5GHz 256-bit) : Floating-Point (High/Double Precision) : GP(GPU) call failed. Try another interface (e.g. OpenCL/ComputeShader/CUDA/etc.) or update video drivers.
Finished Successfully : No
Analysing...
Aggregated Score : 12.59GFLOPS
Speed : 3692MHz
Capacity : 8Unit(s)
Power : 200.00W
GP (GPU/CPU/APU) Bandwidth
Analysing...
Error (5408) : CUDA GP Processor : NVIDIA GeForce GTX880M (1536SP 8C 953MHz/993MHz, 512kB L2, 8GB 5GHz 256-bit) : Out Of Memory
Warning (2003) : CUDA GP Processor : NVIDIA GeForce GTX880M (1536SP 8C 953MHz/993MHz, 512kB L2, 8GB 5GHz 256-bit) : Use a larger page file or install more memory. The page file usage is over 90%.
Aggregated Score : 35.602GB/s
Result ID : NVIDIA GeForce GTX880M (1536SP 8C 953MHz/993MHz, 512kB L2, 8GB 5GHz 256-bit) (OpenCL)
Speed : 4994MHz
Capacity : 8192MB
Power : 100.00W
Overall Score
Aggregated Score : 8.84kPT
Results Interpretation : Higher Scores mean Better Performance.
Decimal Numeral System (base 10) : 1GPT = 1000MPT, 1MPT = 1000kPT, 1kPT = 1000PT, etc.
Result ID : MSI GT70 2PE (MSI MS-1763) (Intel Core i7-4800MQ CPU @ 2.70GHz; Intel Core DRAM Controller; 2x 6GB Kingston MSI16D3LS1KBG4G DD; HGST HTS721010A9E630; NVIDIA GeForce GTX880M)
