M mesk47mk Commendable Feb 4, 2017 7 0 1,510 Feb 4, 2017 #1 Recently I bought a new BenQ XL2430T and every thing has go fine still the sound I did try many options to solve it but nothing helped.
Solution P P Paul NZ Feb 4, 2017 Is this it?? If it is the driver is here Select support and downloads / the operating system download then run the install
P Paul NZ Polypheme Sep 15, 2014 20,774 3 61,010 Feb 4, 2017 #2 Did you use an HDMI or DP cable? Upvote 0 Downvote
M mesk47mk Commendable Feb 4, 2017 7 0 1,510 Feb 4, 2017 #3 I used both of them but DP didn't work at all in the other side HDMI just screen on but no sound. Upvote 0 Downvote
P Paul NZ Polypheme Sep 15, 2014 20,774 3 61,010 Feb 4, 2017 #4 Did you install the videocard drivers? Upvote 0 Downvote
M mesk47mk Commendable Feb 4, 2017 7 0 1,510 Feb 4, 2017 #5 I do not have CD player so that i couldn't put the CD on. I tried to download form google but I do not think that is was correct file. Upvote 0 Downvote
P Paul NZ Polypheme Sep 15, 2014 20,774 3 61,010 Feb 4, 2017 #6 What videocard do you have or if its onboard what is it?? Upvote 0 Downvote
P Paul NZ Polypheme Sep 15, 2014 20,774 3 61,010 Feb 4, 2017 #8 That's whats on the videocard. You have to find out, what the brand/model of the videocard is that it's on. So you can find the right driver for it Upvote 0 Downvote
M mesk47mk Commendable Feb 4, 2017 7 0 1,510 Feb 4, 2017 #9 How can I found the brand/model of the vediocard. Upvote 0 Downvote
P Paul NZ Polypheme Sep 15, 2014 20,774 3 61,010 Feb 4, 2017 #10 Open the case and look at it if it's a desktop Upvote 0 Downvote
M mesk47mk Commendable Feb 4, 2017 7 0 1,510 Feb 4, 2017 #11 I just got what you mean. Upvote 0 Downvote
M mesk47mk Commendable Feb 4, 2017 7 0 1,510 Feb 4, 2017 #12 Its * Gigabyte GeForce GTX 1070 G1 Gaming Video/Graphics Cards GV-N1070G1 GAMING-8GD * Upvote 0 Downvote
P Paul NZ Polypheme Sep 15, 2014 20,774 3 61,010 Feb 4, 2017 Solution #13 Is this it?? If it is the driver is here Select support and downloads / the operating system download then run the install Upvote 0 Downvote Solution
