Yes i purchased this http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4652281&CatId=5469 its the gl2450ht. When i got it it didnt even recognize the hdmi cable it said there wasn't one in so i had to use a damned dvi cable well... Now ive seen some tips on how to fix it and i did but, with that being said whats this 60hx works perfect with hdmi but you need dual dvi-d connector to reach anywhere from 100hz to 144 hz. Im very very confused when i got my monitor yesterday it only came with a manual a cd driver disk and a vga cable seriously nothing else it was supposed to have a dual dvi-d cable and an hdmi which it didnt with so i have already got onto tiger direct and benqs ass about this. If anyone has any suggestions or insight on this monitor please let me know thank you. Im running on a brand new ryzen 1800x system with an asrock x370 taichi mobo, 16 gb corsair lpx2 300 ram (which i can only get to run at 2667 mhz or it doesn't boot and i need to rerset the cmos) I have 2 rx 480 8 gb's (but do plan on getting a vega frontier when they come out and a threadripper -yes I want a beast i stream so i need a beast) and asll the other parts youd find in a fancy expensive computer that are top teir.
well basically spent 2500 on everything and i want to run and play as smooth as a babys butt with the amount of credit i had to use to get this. Any thoughts, ideas, insights would be really helpful thank you.
