Benq monitor stuck @ 60hz
Well, most monitors can accept only 60Hz signal. So it may refresh the screen 75 times, but then again it is useless as only 60 frames come in every second.
Btw - sometimes you can press them a little bit but rarely comes something good out...
^That is true. I have 3x Asus 27" monitors all run at a native 60Hz refresh rate even though according to the specs like yours they have a Vertical Refresh Rate 50 - 85 Hz. Your monitor is at the refresh rate it should be running at do not worry about it 60Hz is the optimal setting for that monitor.
No they are not falsely advertising. The 76Hz is the MAXIMUM rate but if you are running at the native resolution (1080p) then the maximum refresh rate would be 60Hz. Old CRT's where the same way to higher resolution the lower the refresh rate.
it does not allow 75hz @ 720..
Are you connected using HDMI? You have to use DVI-D for 75Hz at 720p. HDMI 1.4a and below cannot go above 60hz.
im using DVI-D
i could say the same about your ACER.. lol
2ms vs 16ms is a big difference. Though I see on newegg it shows 4ms.
