S Sepyuu Reputable Oct 7, 2014 13 0 4,510 May 19, 2015 #1 Hi guys! I want to make the most of this screen, what cable should I use? HDMI? DP? DVI? I'll be hooking it up to a 980 GTX. Thank you!
Solution Sandstorm3000 May 19, 2015 Since its a 1080p monitor it wouldn't matter. At this resolution you just can't tell so just use whatever is the easiest for you.
Sandstorm3000 Honorable Aug 8, 2014 1,059 0 11,960 May 19, 2015 Solution #2 Since its a 1080p monitor it wouldn't matter. At this resolution you just can't tell so just use whatever is the easiest for you. Upvote 0 Downvote Solution
Sandstorm3000 Honorable Aug 8, 2014 1,059 0 11,960 May 19, 2015 #4 Sepyuu : Roger that, thanks! No problem Upvote 0 Downvote
