Whilst installing my CPU, I accidentally bent the pins slightly. I was worried but I went ahead anyways. The computer is stable, and nothing is really wrong, but when I try overclocking a little bit the heat shoots up.
I'm running a i5 4670k with a 212 hyper evo cooler. At stock speeds of 3.4 to overclocked at 3.6 it runs at around 71 degrees celcius under full load. However, pushing it any higher than that causes temps to shoot to 90-100 degrees.
I've heard that this CPU runs hot, so I just wanted to confirm a couple of things.
1) Could my early bent pins be causing this? (Even though it runs at 31 degrees idle regardless of overclock and seems stable? Can bent pins make it run extremely hot when OC'd?)
2) Is it that I just have a bad CPU?
3) Is this relatively ordinary for the 212 Evo? Or should I be expecting much better. Aka, can I simply change my cooling system 2-3 years in the future and OC to higher, or is this CPU/bent pins bad and I should fix this now?
