Question Bent Mini USB connection.
snackthegreat
4
In my h115i pro the Mini USB connection on the AIO pump is bent on the inside. I cannot plug in the cable so I cannot change the RGB for it. It is stuck on an ugly yellow color lmao. Is there anyway I can fix it? Like moving one of my fan cables to a RGB header or something of the sorts to get RGB control?
Lutfij
You might want to parse an image to show the extent of the damage of the connector. As for your question, best stick to the connectors that the unit is meant for instead of reverse engineering things to end up with a dead AIO oe worse a dead system(due to a short).
Lutfij
