So I got a Biostar Tz77mxe lga 1155 motherboard a few days ago. Due to a mistake by me, I accidentally bent a few pins. After spending a few hours trying to bend them back using a sewing needle, they look pretty straight. That is when you look from the very top. The pins that were bent now sit higher then the ones that were not bent. Is this a big problem and could this pose a threat to my cpu? I am mostly worried that because some of the pins are higher than others, the cpu will have one side slightly elevated than the other, thus the cpu contacts not touching all the mobo pins. Is there any way to fix this? Is this a serious problem?
