Hello. I recently got the last part of my PC gaming build, the parts of which I have been waiting for a good 1,5 month.
I will begin with stating the specifications:
Intel Core i5 6600K - Skylake Processor
Gigabyte GA-Z170X-Gaming 3 - Motherboard
Noctua NH-D15 - CPU Cooler
HyperX Fury 2x8GB 2666MHz - RAM
Gigabyte GTX 1060 G1 Gaming - GPU
It started off great. I was reading the manuals and throughout the process of every component installed I was extremely careful to do it correctly and not break anything.
I started with installing the CPU onto the motherboard, I did this outside the case not that it is relevant to my knowledge. I simply lifted the foot holding it in place, carefully looked at the CPU and the manuals (which were horrible for every component I had) and made sure it was properly installed. I aligned the notches and whatnot, and I carefully dropped it onto the motherboard. I heard a sort of "tchh" sound or how to explain it, I knew it was in place correctly at least. It did not stand on the pins, it was just sitting in the socket. So I removed the plastic cover, I put the holder back in place, and as I bent it back I heard a small cracking noise, very small noise which I was reassured of was supposed to be happening as the CPU is fully put in to the socket when it happens and I thought it was all good.
So I put the rest of the PC together and did a test boot after mounting the motherboard in the case etc. The PC did not start. I decided to deattach all components and I got to the CPU and checked the processor. The processor was slightly bent on both corners of one side. The other side was to my surprise straight and did not seem to have been damaged at all.
So I double checked when removing the CPU that I had in fact put it in place correctly and I came to the conclusion that I had. Now I am devastated because I know warranty usually doesn't cover these things and I have just thrown ~ 245€ = $275 USD out the window.
I do not know what to do. I don't know if the CPU is beyond saving or not but I guess it is because I assume it's hard to bend it back in a good manner and even if it isn't I guess the circuits could still have been damaged.
I have no idea however, how this can have happened as I made it my life goal to be extremely cautious while doing this 🙁.
I did already send an email to the retailer I bought this from, and wrote an essay about my problem. I also mentioned that I have read that Skylake CPU's are known to have had cases where they have bent slightly because of the pressure of big 3rd party CPU coolers (Such as Noctua NH-D15, which is HUGE.)
So I did some research and saw that others have had these kind of issues too. Now is there any chance in hell that I can get a new CPU with the warranty or am I screwed?
To my knowledge, there is no visible damage to the CPU socket. It looks good but I am not a PC expert (obviously, heh 😀) so I wouldn't know.
Hoping some good soul here on Tomshardware can help me out... Thanks!
Some pictures of how it looks like (taken straight out of Internet because it's late here right now but I am willing to take my own if it helps):
EDIT: In case anyone is curious about how things went, I ended up not getting any warranty. BUT I did bring the Skylake back to life with the help of a good friend! He had a heatgun that we used to heat the PCB and then we just applied slight pressure to bend it as straight as possible, and boom, now I'm on Windows and everything seems to be working perfectly! Aida stress tests and other benchmarks show everything to be just fine! I am so happy about this 😀
PS: I also read that Intel know about the issue that Skylake CPU's may be bent in general easier than other CPU's they have. I also know for a fact that the Noctua Cooler mounting is incredibly well made. It has a backplate and good screws holding it together.
