Question bequiet Pure 500FX ARGB hub connection to motherboard
vblanche
Commendable
Mar 22, 2020
Hello,
I have a case bequiet Pure 500FX , there is a RGB hub but I don't really understand the connections I need to do to my motherboard, MSI mortar B660M wifi DDR4. it is pre-wired, so connections of fans to the hub are ok. what should I plug on the motherboard?
thanks
So, it looks like you need to connect the ARGB hub to a SATA power connector coming from the power supply.
And then you need to connect the three pin ARGB connector from the hub to a three pin ARGB header (Labeled JRAINBOW1 and JRAINBOW2 ) on your motherboard.
Which can be located BELOW on YOUR motherboard and are outlined in green:
Reactions: vblanche
many thanks for your reply.
I indeed connected the hub to psu but was not sure about connecting the 3pin ARGB connector to a JRAINBOW header, don't understand what it will do. anyway, thanks again.
