Best £30/$50/€43 USB Microphone for Gaming?
Ike0
135
Hi guys,
What is the best USB mic that I can get for £30 that will sound crisp and clear?
I would like one that only picks up my voice and nothing else.
Thanks
generally the blue snowball is a good budget choice at $45usd though prices may vary in different countries. uk typically has much higher prices than elsewhere. its a cardioid mic so picks up what you point it at and likes to ignore sources you dont point it at.
as mentioned above if you did not mind a 3.5mm mic, the modmic is a great option if you would prefer hooking up a boom mic to an existing pair of headphones.
