Best £50 ATX Mid-Tower case?
overlordofdoom
79
The title says it all. I've looked at cases like the phantek p400 but I've seen that it has even worse air flow than the corsair carbide 100r. I just need a case that has good airflow, can fit a 160mm cooler and a wide panel. I've looked all over and only the phanteks p400 and corsair 100r stood out. Thanks.
84? Damn I was already stretching it with 50, Thanks anyway.
lol no problem. Yeah that was one of my consideration but the glossy finish is not for me. Funny thing is this case: http://www.novatech.co.uk/products/components/cases/midtowercases/bfx-nov-100-kkwsk-rp.html is really cheap and actually performs better than the phanteks and similarly to the s340
Hah, yeah. I think its a bit cheaper because its a bit older.
I found a few more cases:
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16811119233&cm_re=mid_tower-_-11-119-233-_-Product
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16811146214&cm_re=mid_tower-_-11-146-214-_-Product
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16811139043&cm_re=mid_tower-_-11-139-043-_-Product
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16811139041&cm_re=mid_tower-_-11-139-041-_-Product
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16811146181&cm_re=mid_tower-_-11-146-181-_-Product
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16811119277&cm_re=mid_tower-_-11-119-277-_-Product
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16811353093&cm_re=mid_tower-_-11-353-093-_-Product
Any of these work? The Razer S340 I just threw in there because it was a matte finish.
Woah that's a lot! Thanks. The DIYPC D480-BK-Window looks good. Also the prices it shows are without vat, one of the great things about the uk 😉. So the DIY turns out to be £94 with shipping, with that much i'd rather go for the corsair 400c.
