Hey guys! I am looking for the best 120 mm Blue LED fan for my PC. By best I am referring to the amount of airflow(CFM) and the highest static pressure. I would like to use them for my CPU radiator and my case so I can move as much air through as possible. I would prefer The solid square frame style if possible because those frames seem to fit my radiator best. I tried some CoolerMaster Jetflow 120mm and I was not impressed and I do not like that frame style, a lot of air was blowing around the sides back into my case. If there are higher airflow or performance fans that anyone has in mind I am also open to not necessarily having blue LED's, I would just prefer the LED fans since they match my PC and components. I don't care about high fan noise as long as they don't rattle, also not worried necessarily about price. I just want the best! Thanks!
