I want to get a Arctic LQ 2 360mm but the only options I have in my country are with the non ARGB fans and I want some lightning inside my PC (I've used Silent Wings 3 for about 5 years now and I'm tired of the same black look every day). So I've thought to maybe maybe 3 replacement fans for the AIO with ARGB and I can't decide which ones to get. I was thinking of bq!'s Light Wings but do get the same CFM etc. as the P12 coming with the AIO I need to get the High Speed one's and they're much noisier.
Currently I'm planning on getting the 4000D airflow but I could upgrade to the iCUE 4000D Airflow and get the 3 AF120 ARGB preinstalled fans and replace the AIO ones with those And put the AIO fans at the top and back (or maybe the other way around). What do you think? What ARGB fans would you suggest to install on the AIO? I'll fill all the fan slots of the case (top and back) with 120/140 mm ARGB fans eventually.
I also can't decide: 4000D Airflow or 5000D airflow? I'm more concerned with ease of build (if for example connecting the EPS cable is a pain (with/without fans installed) or pretty ok) or maybe fitting the 420 version of the LQ2 at the front.
