Best 140 Fans for Exhaust
Joao Santo
23
So i want fans, anda few more things, i have 100€ to spend i plan to get
- x2 140MM FANS FOR TOP EXHAUST
- White or Blue LED Strip
- Fan splitter for those fans.
ALL OF THIS CAN?T COST MORE THAN 100€ on amazon
Can u help? 😀
1st- I need a led strip that ships toportugal and is dispatched by Amazon
2nd - I have the CM 690 III case, and the fan header left is at the bottom of the case will there be enough cable (fans cable + splitter cable) for reaching that fan header? I will put the fans on top
First tell me. You need 3pin or 4pin fan splitter? And how much length do you require exactly. Because i dont have that case . givr an idea of how much do you want. Secondly amazon.co.uk also ships to portugal but they may charge vat and shipping . so you can get the led strip from amazon
