[SOLVED] Best 1440p 144hz monitor suggestions
Padipadil
22
So im thinking about upgrading my benq xl2411z 1080p 144hz display for either a VA or IPS 1440p 144hz monitor. Mainly because the new videocards dont support dvi which my current monitor uses for 144hz(no display port). So im kinda stuck with this GPU until i buy a new monitor with display port. I play games such as Rocket League, Warzone, Battlefield, Mmorpgs, GTA, RDR2 and some netflix so bascally everything but mainly shooters and rocket league.
My budget is max €450
Monitors i found:
LG UltraGear 27GL850 (350 used, 450 new)
LG Ultragear 27gl83a-b (450 new)
AOC cq27g2 (300 new)
ViewSonic VX2758-2KP-MHD (360 new)
Asus vg27aq (450 new)
If theres any better VA or IPS monitors let me know (i would prefer a good VA with minimal ghosting but i dont mind a IPS with minimal glow,bleeding)
At first glance I would lean towards the ASUS. But if you prefer VA then the VG27WQ would be its cheaper cousin.
I don't think the LG 27GL850 would be bad, if you can get it for 350, that is a decent bargain.
