Best 144hz Monitor?
Depending on where you live because both use the same panel ... the Asus VG248QE or the BenQBenQ XL2411Z. Minor differences.... BenQ cones outta the box w/ better color balance buyt suffers from ghosting which is noticable to some but not all gamers.
Make sure to download an ICC profile from TFTcentral
Also you can add motion blur reduction with tasty strobelight.. works on the Asus, not sure about the newer BenQ
http://www.blurbusters.com/easy-lightboost-toastyx-strobelight/
Well, im currently using a BenQ XL2411Z and i would highly recommend this monitor i have been using it for a couple of months and have had no problems at all. It also is well fit for your budget. When i got it it was about 200-220 pounds. Its currently unavailable on amazon but there are plenty of other websites that will sell it.
Hope this helps! 😀
