I have a large form factor Dell OptPlex 9020. What would be my best options for a bracket or converter to mount a 2.5 inch SATA SSD into in order to fit it into a 3.5 inch hard drive slot in my computer?
I see that there are multiple types and designs, some of which are metal, some plastic, some allow more airflow than others, some require screws, some are tool-less, some are just brackets to fit the SSD into, some feature a SATA plug that fits into the SSD and which the PC SATA cable is in turn supposed to plug into, and some even have shock absorption. I'm not sure what is the best option.
A few different ones that I've been looking at:
https://www.amazon.com/Corsair-Dual-Mounting-Bracket-CSSD-BRKT2/dp/B0090UG55A/
https://www.amazon.com/Fenvi-Converter-Bracket-Internal-Mounting/dp/B074K95T4X
https://www.amazon.com/Sabrent-Internal-Mounting-Bracket-BK-HDDF/dp/B00G56ZNZU/
https://www.amazon.com/Corsair-Dual-Mounting-Bracket-CSSD-BRKT2/dp/B016498CK0/
https://www.amazon.com/Sabrent-Internal-Drive-Mounting-BK-HDDH/dp/B00G57BN1M/
https://www.amazon.com/ORICO-Adapter-Mounting-Bracket-Interface/dp/B01LZWX6PD/
