Best 24' 144hz monitor for gaming?
Reksi007
67
So i've been using a 60hz monitor till this day and i heared a lot of people telling me the diffrence beetwen 60hz and 144hz is big which is why i'd like to buy a monitor that is 24',144hz,1ms.
I've looked at:
ASUS VG248QE - 280€
BenQ XL2411 - 293€
I've heared that the VG248QE has a bad image quality and is Quite outdated.
Or perhaps the ASUS MG248Q would be good?
So i'd like to which monitor is great, meets the requirments and is around arond 300€.
It'll be used mostly for gaming games like CS GO.
I'M USING AN AMD CARD
VG248QE and MG248Q look the same to me. Both are TN monitors.
The only difference is MG248Q has FreeSync, the other one not.
TN monitors have bad image reproduction compared to IPS and VA.
But for that price range, if you want 144hz monitor, you can only have TN monitors.
Yea...But do you know any better monitors then those 2?
Ye i've looked at it looks quite nice but i'll have to buy it from amazon.de since it's not here in Slovenia.
If you want a 144hz monitor within that price range, no, there is nothing really better.
The only ones better are the 144/165hz IPS monitors, which are quite a lot more expensive.
Do u think there's any game changing diffrence with the AOC G2460PF and ViewSonic VG2401MH? Apart from the 50€ diffrence.
There's one more thing it'd like to know. Since i'm really into CS:GO i would like to know how much lower input lag Will change the experience. Like the input lag diffrence beetwen ViewSonic XG2401,ASUS VG248QE, BENQ XL2411 and the AOC G2460PF. I'm sry but this just seems to be what i'm most sceptical about.
