Best 24-27" Battlefield 4 monitor for 200$
I'm actually upgrading from that monitor :/, also 1ms response times help with motion blur reduction and makes the picture much more clear
in that case, theres nothing much to upgrade to, unless ur willing to pay 250 and get a 144Hz panel
I agree with davidarad02. Save up $50 and get a 144Hz monitor. You'll probably be using the monitor for awhile; $50 extra is worth the investment.
FYI. I noticed you created the same post yesterday except you were asking for good color reproduction with 1ms for $200.
I don't really have much money saved at the moment. I'm only 15 I can't work so money doesn't come in that often so I'm trying to find the cheapest prices possible
so theres nothing much to do. try asking your parents if the can help you out with 50 bucks, a 144Hz panel is what you are looking for right now. also, consider if your GPU is also capable of playing BF4 144Hz. what do you have?
I spent most of my money on a gtx 980 which I got off of craigslist for 300$. It's a gigabyte and it runs amazing. I get 130fps in battle at max settings on battlefield 4. Best thing k could of done to my machine. My 270x's couldn't run anything before, I have about 140$ now which I know isn't even close to enough for a 144hz monitor. I guess I could ask my parents for a little financial help, maybe they could help me out. I do have a 144hz monitor in mind. It's the benq XL2411Z
if your parents agree, good for you. if they don't, theres not much you can do.
Just tell your parents that you'll be using the monitor for many years and that you'll regret buying a $50 cheaper monitor that you'll not be completely satisfied with. Maybe you can do some house work for the extra $50.
Ok thanks for the help :)
