G GekkiPlayz Reputable Jun 2, 2015 24 0 4,510 Jun 28, 2015 #1 Hi, I was wondering what the best CPU cooler for a 4790K for max. 30$ is. Thanks!
Solution N3rdR4ge Jun 28, 2015 this is the #1 budget cooler. http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&cm_re=212_evo-_-35-103-099-_-Product http://www.amazon.com/Cooler-Master-Hyper-212-RR-212E-20PK-R2/dp/B005O65JXI/ref=sr_1_1?ie=UTF8&qid=1435537505&sr=8-1&keywords=212+evo
N3rdR4ge Distinguished Jun 16, 2014 4,202 2 18,965 Jun 28, 2015 Solution #2 this is the #1 budget cooler. http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&cm_re=212_evo-_-35-103-099-_-Product http://www.amazon.com/Cooler-Master-Hyper-212-RR-212E-20PK-R2/dp/B005O65JXI/ref=sr_1_1?ie=UTF8&qid=1435537505&sr=8-1&keywords=212+evo Upvote 0 Downvote Solution
G GekkiPlayz Reputable Jun 2, 2015 24 0 4,510 Jun 28, 2015 #4 Is the 212 Plus better or worse? Or the same? Cause I found it for 19$ Upvote 0 Downvote
N3rdR4ge Distinguished Jun 16, 2014 4,202 2 18,965 Jun 28, 2015 #5 GekkiPlayz : Is the 212 Plus better or worse? Or the same? Cause I found it for 19$ the plus is a downgrade heres a comparison video i watched before i bought mine https://www.youtube.com/watch?v=3zwysAvIdYY Upvote 0 Downvote
KKAW Admirable Apr 29, 2015 2,225 0 6,960 Jun 29, 2015 #6 I use a hyper212x turbo dual fan ocd my 4690k to 4.5 ghz. Define mild overclocking. If ur oc ur cpu to. 4.1ghz or less it will make no difference to your performance so i would suggest getting my cooler or an evo 212 and get the oc as far as u can Upvote 0 Downvote
N3rdR4ge Distinguished Jun 16, 2014 4,202 2 18,965 Jun 29, 2015 #7 i have i5-4690k 4.6ghz @ 1.28v stable with cm hyper 212 evo. temps on prime95 v26.6 range from 65c-75c. Upvote 0 Downvote
