Question Best 4K - 144Hz Monitor ?
danielm175
328
11
18,785
Hi,
I am looking for a new 27-28Inch, 4K, IPS, 144Hz monitor.
Which is the best gaming monitor with those specs ?
No budget, just the best with those specs.
Few suggestion:
if you are set on 4k, try for 32". you have all those pixels and 4k for 27" would be overkill.
If you sit in front of the monitor, i would suggest looking at VA panels instead of IPS. the technology has come a long way to give sufficient colour accuracy in VA panels and they have better contrast than IPS for better viewing experience in dark scenes.
or better yet:
Few suggestion:
or better yet:
I do have a question. Let’s say you where going to go with an RTX 4090.
Is it better to get a 2k monitor high refresh rate
Or get a 4K monitor at 144hz?
Personally I like 4K but not sure if the RTX4090 is capable of hitting 144hz at 4K ultra settings on modern games?
the 4090 can handle 4k 120hz.
consult the previous pages if you want more detail.
