Best 800MHZ FSB DUAL/QUAD CORE CPU
Q8200/Q8400 are both 1333MHZ FBS.
The problem is that the mobo in the PC I'm trying to upgrade supports 533/800MHZ FBS 🙁
Intel 945GC. It came with a Lenovo 3000 J200 9691 34G desktop.
Thanks a lot guys.. I've upgraded to E4600 2.4GHZ from E2160 1.8GHZ and I can feel a difference especially in games (The 2MB L2 CACHE made the difference)..
Some guys told me that I can overclock easily to 3-4GHZ.. Does my mobo support that? And will it work with the stock cooler?
You would have to check your bios options to determine if you can overclock, Lenovo might have locked those options. Can you increase the front side bus and voltages, or is there a "burn in" option? An aftermarket cooler is recommended if you want to overclock due to the higher temperatures it causes.
