From my experience, 80mm fans are not particularly great to begin with and tend to be a bit noisier than a 120mm fan. Bearing that in mind, I reckon you should try and find a few more bucks and get something like the Noctua NF-R8 80mm case fan.
From this list what do you recommend?
http://pcpartpicker.com/parts/case-fan/#X=0,600&s=80&l=23&sort=d7&page=1
For quiet, as well as fast, go for the Rosewill on there. Beware it has a sleeve bearing though, which won't last as long as Hydraulic, SSO, Ball, etc.
