Best AIO water cooler
Well custom is slightly on the expensive side as I already have all the parts needed apart from the water cooler. I also would be to scared that it would leak. The cleaning would take ages as well. Would you be able to make a full custom loop for around £150 because I would love one just a bit sceptical because of the above
i own kraken x62 and i regret that i didn't take EVGA CLC 280
reason: x62 have a horrible software full of bugs
So the evga is best because of the bundled software, not the build quality.
Gotcha.
Well I own the NZXT hue+ and software is horrible for the price in paid for some LEDs, when it works it’s amazing. So I was thinking x62 because of already haveing the software not needing new software and the infinity leds look sexy but I’m not sure now also I’m most worried about build quality/leaks, if it stops working for some reason ect
software cause 10-15 sec lag when i do stress test on my i7 8700k and that is just one bug..performance is a really great but software not so i would recommend you what i say up for EVGA and i personally will put ML140 pro fans on radiator
you don't need to be worried about leeks on the kraken or EVGA AIOs and they have 5-6 years warranty
