Best air cooler (considering fit) for i5 7600k and corsair 270r case
davidjo
5
This was posted in components but figured might be better suited for cous forum.
Hi all, just wanted to get some air cooling options for my current set up
I5 7600k
Asus z270g
corsair vengeance lpx ddr4
Corsair carbide 270r case
Current cooler: noctua nh-u9b se2
I went with this cooler as the store I bought my parts from didn't have much else in stock. I've since done a bit of browsing and realise this cooler is pretty dated and there's much better ones out there.
Current temps with no overclock are:
Idle 30-33c
Under load using rog realbench for 15 mins max 67 avg about 62-64.
I note that corsair site says max cooler height is 170mm but does this take into consideration mobo etc being in place?
Also one of the fans on my current cooler basically sits right ontop of one of my ram sticks. A few mm gap
With all that in mind, can I get some suggestions for coolers pls
Considering the nhd15 but it's got a height of 165mm will this be too much considering my case listed max of 170? But with mobo etc too?
Also given this is an even bigger cooler, how will it affect the spacing on my ram?
Apart from nhd15 what else is considered best
Also, are my current temps quite standard? Or are they on the high side of this cpu?
The current case fan set up is one in front and one in rear. I'll prob add one more to the front for intake and 2 exhaust up top
Options
As for fittings
My Case CM690III has Max of 171mm but i wanted to buy the Coolermaster Air maker 8 CPU cooler Which is 172mm i was also worried but i thought lets give it a shot
and it worked for me still there is like 3-4MM gap
davidjo
5
I'm leading towards the cryorig r1 ultimate...but I may have some fit issues..
Case max is 170mm / cryorig 168mm
Corsair vengeance ddr4 is apparently 34mm / cryorig ram height clearance range is 30-35mm.
Does anyone know if the ram height clearance at 35mm = the max height if 168mm? As I won't have any room to move
As for fittings
