Solution g-unit1111 Feb 27, 2018 junii : Was thinking like cooler master hyper d92?? That's decent. I would suggest the Cryorig H7: https://www.newegg.com/Product/Product.aspx?Item=9SIA4UF53D6676
jwcrellin Reputable Dec 3, 2016 1,416 39 5,740 Feb 26, 2018 #2 Noctua nh u12s, as long as you have am4 socket https://www.ebay.com/i/232676722149?chn=ps Upvote 0 Downvote
J JalYt_Justin Reputable Jun 12, 2017 1,164 0 5,960 Feb 26, 2018 #3 Scythe Fuma hands down. https://www.amazon.com/Scythe-FUMA-Rev-B-Cooler-SCFM-1100/dp/B075FX95F2 Upvote 0 Downvote
jwcrellin Reputable Dec 3, 2016 1,416 39 5,740 Feb 26, 2018 #5 Actually back when I bought a tower cooler i went with the cryorig h7 and was very pleased with the noise and temps. Upvote 0 Downvote
junii Notable Feb 17, 2018 280 0 810 Feb 26, 2018 #6 Was thinking like cooler master hyper d92?? Upvote 0 Downvote
g-unit1111 Titan Moderator Jul 27, 2011 42,790 868 104,940 Feb 27, 2018 Solution #7 junii : Was thinking like cooler master hyper d92?? That's decent. I would suggest the Cryorig H7: https://www.newegg.com/Product/Product.aspx?Item=9SIA4UF53D6676 Upvote 0 Downvote Solution
zoltan.boese Estimable Jan 30, 2018 1,550 0 2,960 Feb 27, 2018 #8 Mugen 5 with AM4 mounting https://www.newegg.com/Product/Product.aspx?Item=9SIA9ZH6GN8650&cm_re=mugen_5-_-9SIA9ZH6GN8650-_-Product Upvote 0 Downvote
