I just put together my M-Atx system in a corsair Carbide air 240 case; I initially went with the stock cooler for the cpu because I don't plan on overclocking but I noticed that the CPU is running a bit hotter than I would like (60 C under load)
Was looking for a recommendation for a get air cooler, preferably one that doesn't require a back plate so I don't have to take apart the entire system since I try to avoid doing so whenever possible.
Thank you!
Thank you!
