[SOLVED] Best air cooler for ryzen 3700x
kostask5
226
Have you tried using the stock cooler? From what I've heard it generally does a pretty good job, at least without overclocking.
No the cpu will come in about a month i just saw that its temps get a bit high under load but maybe i will wait and use it first.But do you have anything to recommend either way?
kostask5
226
I'm no expert, but Mugen 5 Rev B or Cryorig H5 Universal would be vote for around 40 to 50 euro.
Thnx for the recommentation both of these look pretty good for their price will think about which one of the two to get.They should do the job just fine right.Is there any need to go for something more expensive?I dont care much about the sound mostly temps
kostask5
226
Both of them are very good mid range coolers. While you can spend more and get a better cooler, you will get diminishing returns and the price/performance just isn't there.
Ok thanks for the help i will propably go for the mugen 5.I also saw the coolermaster hyper 212 evo thats cheaper but looks like its harder to mount.
