i don't know much about overclocking but i am planning to and i am just wonder which is the best air cooler i can get. This is my build so far http://pcpartpicker.com/p/sgL4Lk i am also looking for suggestions on my motherboard anything below 350$.
i see that one is the most commonly used so i was just wondering if there was anything better i don't really want to use liquid because im afraid of it leaking and destroying the computer
I disagree strongly with why_wolf. The i7-5820K is a 140W CPU at stock and is closer to 200W when overclocked That air cooler is not stout enough for that (although it is an excellent budget cooler). When we tested that chip http://www.tomshardware.com/reviews/intel-core-i7-5960x-haswell-e-cpu,3918-3.html the Noctua NH D15 was used. It is one of the best 'big air' coolers out there. I use the very similar NH D15S.
i will be using my computer for streaming/gaming and editing. is the case i picked big enough if you wouldn't mind taking a look at my build i put it in the first post.
wifi wouldn't hurt but no i don't i am hard wired hard wire = amazing compared to wifi which doesn't do crap most of the time thanks for all the help guys it means a lot 😀
It is literally as ugly as sh*t though (bad pun intended)
I'd recommend the Cryorig R1 Ultimate, because it cools slightly better than either of the other coolers, and doesn't look too bad. It is a bit noisier though.
I happen to like ASRock at most places in the market because of their great price/performance. (cheaper than better, better than cheap), so I'd start with the ASRock X99 Extreme6/ac at about $250. What features do you need that requires you to spend more? (I also like WiFi. I need it to access networks at school)
I will look into them thank you oatie, I am just looking for a board that is stable and wont have any issues when I try to overclock. I looked up the reviews for the asrock board on newegg didn't look to well. does not need anything special since I use hardwire? question you said you needed wifi on a board for school do you carry your tower into school? lol
