Best Airflow possible? (NZXT 220 & 5 Fans)
Andrei_316
283
Hello there!
I'm about to buy the CM Devastator M & Kb cause I need something that does the job for cheap and I'm also gonna buy 2 more fans cause the fan grills being empty piss me off for some reason ;-; and its only $6 for 2 so why not? 😛
Here is a picture:
This is the current fan setup (but I switched the exhaust to the top because of the way the 212 is) :
There is a total of 6 Fans Slots (2 Front, 2 Top, 1 Bottom, & 1 Back) and I will have 5 Fans in total (3 NZXT White LED & 2 Rosewill Standard Fans, all 120mm). Where should I install the fans for best airflow? I can also somewhat fit a fan in the 5.25' bays.
**My wiring is cleaner now if you're wondering, picture was taken the first day I built it.
