M memmeeyee Commendable Nov 16, 2017 90 2 1,545 Jun 17, 2020 #1 Looking for cheap custom PSU cables to alternate from the stock PSU that are compatible with the Thermaltake Gold. Looking for preferably white ones. Last edited: Jun 17, 2020
Solution M M memmeeyee Jun 17, 2020 hold on found this https://www.amazon.com/uphere-Sleev...169&s=electronics&sr=1-4&tag=awesomenetw07-20 even though they are extensions, im not gonna even see the stock cables, they are gonna be covered. Plus they are high quality, come in a set, and cheap.
popatim Titan Moderator Dec 2, 2009 39,135 1,041 136,890 Jun 17, 2020 #2 What's the model# from the label on it? Upvote 0 Downvote
M memmeeyee Commendable Nov 16, 2017 90 2 1,545 Jun 17, 2020 #3 popatim said: What's the model# from the label on it? Click to expand... TPG-0750FPCGUS-R Upvote 0 Downvote
popatim Titan Moderator Dec 2, 2009 39,135 1,041 136,890 Jun 17, 2020 #4 https://www.moddiy.com/products/The...-RGB-Individually-Sleeved-Modular-Cables.html https://www.ensourced.net/thermaltake-type-one-power-supply-cables/ Reactions: jonnyguru Upvote 1 Downvote
M memmeeyee Commendable Nov 16, 2017 90 2 1,545 Jun 17, 2020 #5 popatim said: https://www.moddiy.com/products/The...-RGB-Individually-Sleeved-Modular-Cables.html https://www.ensourced.net/thermaltake-type-one-power-supply-cables/ Click to expand... sorry if im being picky but I can only purchase off amazon for some weird reason Upvote 0 Downvote
M memmeeyee Commendable Nov 16, 2017 90 2 1,545 Jun 17, 2020 Solution #6 hold on found this https://www.amazon.com/uphere-Sleev...169&s=electronics&sr=1-4&tag=awesomenetw07-20 even though they are extensions, im not gonna even see the stock cables, they are gonna be covered. Plus they are high quality, come in a set, and cheap. Last edited: Jun 17, 2020 Upvote 0 Downvote Solution
popatim Titan Moderator Dec 2, 2009 39,135 1,041 136,890 Jun 18, 2020 #7 Nice find! Upvote 0 Downvote
