Hello everybody,
I've just purchased the DeepCool Castle 240 AIO and realized it won't fit at the top of my case because it's too thick.
I'm here to ask your opinion on what would be the best position for it (excluding the top section).
You can see below my case on the inside.
Options are:
1: At the front, removing the 2 top fans (otherwise I wouldn't have the screw holes to install the radiator actually occupied by the fans) positioning the fans on the top case, but in this case I would leave the GPU with less ventilation.
2: At the bottom, but here the AIO fans won't have any clean air to pull inside, plus it would make the PSU section hotter.
Option 1 could be the best, but not aesthetically, making from outside the front of my case fanless with the radiator exposed.
Thank you in advance.
Options are:
