Best and Cheapest Graphics Card to Max BF3 at 1366x768?
CitricThunder
13
So, I am building my first PC, but need some help with the graphics card. I currently have the XFX HD 7770 for $130, but I am wondering if I can buy something cheaper but still be able to max BF3 at 1366x768. I also would like it to be able to run Crysis 3 at decent settings. If at all possible, I would love to stay under $150.
Yeah I would go with the 7850. Maybe drop the keyboard and go with one you have laying around the house so you can swing that 7850. I love it for 1600x900, so it could only be better in a lower resolution. If you need it right now there is an XFX 7850 for 159.99 after MIR (http://www.newegg.com/Product/Product.aspx?Item=N82E16814150642&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=3938566&SID=), but if you wanted to future proof or install a ton of mods you could go with a 2 GB version (http://www.newegg.com/Product/Product.aspx?Item=N82E16814150642&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=3938566&SID=).
Hope this helped. Also, if you are ordering soon, Newegg has a new customer discount of 10 off a purchase of 50 or more so that...
You wouldn't be able to go cheaper then your card and get good settings with BF3. You are at the entry point for gaming with your card. You should check out the Crysis 3 Beta right now and give it a go and see how it runs on your computer. Now is the time if you aren't sure if you are going to buy the game or not to at least take a look at it.
I'm still choosing parts to buy. Haven't built it yet. Probably should include the link to my build. http://pcpartpicker.com/p/tQAG. But tried the Crysis 3 beta on my old Alienware M15x w/ GT 240M and got "need a DirectX 11 Card" error. Lol. But anyways, I see the recommended Crysis 3 card is the 5870 and the BF3 recommended is the 6950. Kinda confused how you need a newer card for BF3.
I made some modifications to your build. Firstly you are using a non overclock motherboard chip so I moved you to a i5 3470. Also if you aren't overclocking you really don't need a aftermarket cooler. Also, I changed the power supply to a stronger quality unit. You should also Subtract 20 dollars from that total because there is a promo going through the 4th of Feb on that unit on top of the rebate in the end the power supply amounts to $49.99 after its all said and done. I also changed your case to save a little more to give you room for a 7850 2 gigabyte card you can place a 1 gigabyte card in if you wanted.
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($149.99 @ Microcenter)
Motherboard: ASRock Z75 Pro3 ATX LGA1155 Motherboard ($82.55 @ Newegg)
Memory: Corsair 4GB (1 x 4GB) DDR3-1600 Memory ($19.00 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($73.49 @ Outlet PC)
Video Card: PowerColor Radeon HD 7850 2GB Video Card ($179.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($34.99 @ Newegg)
Power Supply: Corsair Enthusiast 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($69.99 @ Newegg)
Keyboard: AZIO Levetron Wired Gaming Keyboard ($37.86 @ Newegg)
Total: $666.85
(Generated by PCPartPicker 2013-01-31 17:42 EST-0500)
I thought the 3570k was OC'able, no? Thanks for the help though.
Well a 7770 would not be a good match for the i5 3570k. Don't know why you would spend so much on a cpu and then skimp on the graphics card when games are mostly graphics dependent. That is unless you plan on mainly using this build for something else.
at that resolution an a10-5800k trinity will play at max settings. that will run you $120, you get the CPU and GPU in one.
at that resolution? you most certainly will get max settings. you get max settings at 720p with most games and an apu... and that's lower then that.
and that's at nearly 2x the pixels of the res he's playing at.
Man, I really just don't know what to say. You guys really didn't answer my question, more of just arguing about the trinity. From what I've heard on other sites is I don't need anything better than a 7850 with my resolution
Hope this helped. Also, if you are ordering soon, Newegg has a new customer discount of 10 off a purchase of 50 or more so that could help too.
^ +1
Right I believe at your resolution that nothing above a 7850 is needed most definitely. Was just getting frustrated because you are trying to max BF3 not just play the game which you will be able to do with a 7850 and most definitely be better off with the 2 gigabyte card.
Yeah I know I don't really like it when people talk about maxing the game either but I want to do it because I absolutely HATE low quality. I'm gonna go with a 1GB 7850 and if I save enough money i'll upgrade to a 2GB before I buy it. Thank you guys for all your help!
