[SOLVED] Best and/or cheapest card to go with 2200g Rainbow Six siege
justsean035
9
I have a 2200g and im want to get a card that can get me around 144fps at 1080p now and then hopefully better performance when i upgrade. I've been looking at the 1070 for 144fps on low settings but idk if the 2200g will bottleneck it under that. i have a 500w psu, b450 atx auorus elite, and 8gb of ram. I was also looking at the 2060. i'm willing to do low with 100% render resolution
Your 2200g is well matched to the integrated graphics it provides.
To see how it might do with a stronger graphics card, run this test:
Lower your resolution and quality settings and run your games.
If you get better fps, you can take advantage of a stronger graphics card.
A Quality 500w psu will run a card as good as a rtx2070 or a GTX1080
