Best and perfect graphics card for motherboard - VGC-RC310G
Fatalitymercer
Commendable
Dec 20, 2016
6
My father has found a PC and its motherboard is the VGC-RC310G from Sony and since that the graphics card is outdated i would like to find a replacement for it...I live in Hong Kong so the currency is in HKD.My budget would be around 1k hkd.I would like to find a graphics card that can work smoothly and those not affect the other equipment inside it.
[strike]I'm not 100% sure, I guess the motherboard still has got a AGP Slot which makes upgrading to something "new" pretty much impossible.
What are the rest of the specs? (CPU, Ram, PSU)[/strike]
Just found a datasheet:
You've got a x16 PCI Express Slot for the graphics card so upgrading to some better office cards (e.g. NVidia GT730, R7 250) would be the most meaningful way to go. Otherwise you could go with a budget gaming card like the RX460 (that doesn't need any external power)
Depending on what you want to use your Computer for.
So the current graphics card is an Nvidia Geforce 7600GT. CPU is a dual core pentium D at 3.2ghz.
I would recommend a GTX1050 or 1050ti for your budget. Keep in mind that even with the best graphics card, your CPU will be holding back your performance in games. Still, the 1050 should be a HUGE improvement from the 7600.
MERGED QUESTION
Question from Fatalitymercer : "Best and suitable graphics card for my motherboard"
