G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi, I purchased this motherboard to use in my studio for sequencing/audio
editing. I have partitioned the main drive into two, both running XP. [I
switched ACPI 'Off' on install because I want to specify a low IRQ for
my pro audio card as I want this as a high priority device] I have one
partition for pro audio and the other for multimedia. The audio partition
is the most important and I'm running Cubase SX, Wavelab & many plugins, I
also connect a lot of MIDI hardware devices to the machine. I have a
seperate machine running Linux on the internet, I want to keep my audio
workstation clear of the internet due to the many security flaws in XP.
I have an Athlon 2800XP [333] 2x512Mb ram sticks and 1x256Mb stick, all
are DDR400. I also have an Nvidia 64Mb AGP Video card, seperate pro
audio card & MIDI interface, so I don't need any onboard sound enabled. My
Keyboard/Mouse is PS/2, I also have a Thermaltake fan speed controller.
The important BIOS settings are as follows;
Advanced BIOS Features:
CPU Level1 Cache [Enabled]
CPU Level2 Cache [Enabled]
Quick pwr on self test [Enabled]
Gate A20 option [Enabled]
APIC Mode [Enabled]
OS/2 Onboard Mem>64 [Disabled]
Speech POST Reporter [Enabled]
POST Complete Report [Enabled]
Advanced Chipset Features:
CPU External Freq. [166MHz]
CPU Freq. Multiple Setting [Auto]
System Performance [Optimal]
Memory Frequency [By SPD]
FSB Spread Spectrum [Disabled]
AGP Spread Spectrum [Disabled]
CPU Vcore Setting [Auto]
Graphics Aperture Size [64Mb]
AGP Freq. [Auto]
System BIOS Cacheable [Disabled]
Video RAM Cacheable [Disabled]
DDR Reference Voltage [2.6V]
AGP VDDQ Voltage [1.5V]
AGP 8X Support [Enabled]
AGP Fast Write Compatibility [Enabled]
Integrated Peripherals:
Primary VGA BIOS [AGP VGA Card]
USB Controllers [V1.1+V2.0]
USB Keyboard & Legacy Support [Enabled]
USB Legacy Mouse Support [Disabled]
Onboard AC97 Audio Controller [Disabled]
Onboard LAN(Nvidia) [Auto]
Onboard 1394 Device [Auto]
Floppy Disk Access Controller [Enabled]
Onboard Serial Port1 [Disabled]
Onboard Serial Port2 [Disabled]
Onboard Parallel Port [Disabled]
Onboard Game Port [Disabled]
Onboard MIDI I/O [Disabled]
Power Management Setup:
ACPI Suspend to RAM [Disabled]
Video Off Method [DPMS Support]
PWR Button <4 Secs [Soft Off]
Power Up On PCI Device [Disabled]
Power Up On Ext Modem [Disabled]
Automatic Power Up [Disabled]
AC Power Loss Restart [Disabled]
Power On By PS/2 Mouse [Disabled]
Power On By PS/2 Keyboard [Disabled]
PnP/PCI Configurations:
Resources Controlled By [Manual]
PCI/VGA Pallette Snoop [Disabled]
Hardware Monitor:
Q-Fan Control [Enabled]
Fan Speed Ratio [Full Speed]
Speed Up/Down Response Time [2 Sec/4 Sec]
If anyone can sees any setting that they would recommend changing for my
use, please post and give a reason for it, I'd rather understand why I
need to change something than do it blindly because someone suggested it,
if you can see my logic ;o)
Thanks in advance...
APIC Mode [Enabled]
AGP Freq. [Auto]
Hardware Monitor:
