Thanks for the suggestion mr.Bezzell! I'll look into them
yatys93 :
I really like the corsair SP120 blue LED, I have them in my case, although they aren't silent at full speed, they do move a lot of air though, and very quiet if you turn them down a little, if they are going at the front you want the SP version not the AF version.
Edit: actually depends on your case, If you have HD bays behind your intake, even if they are empty, unless they are the older kind that have the wires come out the back not the side, you need SP (static pressure), if you have an open section, the you are better getting AF (air flow) fans instead.
the hard drive bay is.. kinda weird or not typical in most cases today, it looks like this
http://archive.benchmarkreviews.com/images/reviews/cases/Six_Hundred_V2/Antec_Six_Hundred_V2_Interior_Main.jpg
but mine is an antec 600 SE V2 with black interior and the cable management is on the side of the case which gives a big clearance in the Intake fans even if there's a hard drive in there.
About the wires.. are you talking about the wires from the HD's? yes the wires of the hard drives are positioned on the back,
but I routed them to the side where the cable management area is..
I'm a bit lost here, so static pressure is more advisable in my case?
thanks for your time & suggestion mr. yatys93
I appreciate it!
