Best Budget Graphics Card for G4600 for Mid- High Settings
Feb 24, 2015
122
My choices are:
2gb ddr5 MSI GT 1030
2gb ddr5 PowerColor RX550 Red Dragon
2gb ddr5 Sapphire RX560 Pulse OC
2gb ddr5 Galax GTX 1050 OC
2gb Palit GTX 1050 StormX
Which one is good for at least mid-high settings on most games on a pentium g4600 and on a budget of 100$???
IF your PSU is 400W or above you should consider older second hand cards, as mentioned by Robert Ban.
If not then sticking to a GTX 1050 should serve you pretty well for at least the end of 2018 for 1080p@High Settings with around 40-50 FPS.
But if you can get a GTX 1050 Ti within your budget then it would be definitely be worth your while. It will last you at least till the end of 2019 for 1080p@High Settings for 30-45 FPS.
In the end just remember to match your PSU to the Graphics Card you buy.
