Best Budget Graphics Card Replacement for HD 630 on Pentium G4600
Feb 24, 2015
122
I'm Looking for a Great Budget GPU To Replace The HD 630
Can't play 1080p movies on it, has blurry pixels on all pc media players. idk how to solve this, the hd 630 driver is updated to ver. 21
so my pc is:
Pentium G4600
Gigabyte H110M-H
4GB ADATA DDR4 2400
160 GB Seagate Barracuda 2mb Cache
500 GB Toshiba Canvio External HDD
Deepcool DE500
Tecware Quad Cube
NEC LCD w Backlit Led 19" Square Monitor
HDMI to DVI 24 Pins Cable
Running Windows 10 Pro 64 Bit
What Should i Replace/ Place??? The Monitor, cause its LCD and Not IPS or Should i buy a gpu to boost graphics performance?
lg got bunch of cheap monitors, i personally like their design, also the joystick on their monitors make accessing on screen display easier. for sure i cannot really recommend a 1 exact monitor that fit you, as lg got bunch of 1080p monitors with different designs and price. if you want a simple and elegant design, you can get dell's monitor, i like their design, but my main...
maybe you should buy new monitor, i've seen lcd monitor that got blurry pictures, lcd already been pretty outdated either. better upgrade to ips monitor or something equal, try to get monitor that already have 1080p resolution for a bit of future proofing
what led monitor can you suggest that can view these movies perfectly and on a bit of a budget. :)
lg got bunch of cheap monitors, i personally like their design, also the joystick on their monitors make accessing on screen display easier. for sure i cannot really recommend a 1 exact monitor that fit you, as lg got bunch of 1080p monitors with different designs and price. if you want a simple and elegant design, you can get dell's monitor, i like their design, but my main complain with dell's stuffs is how expensive they are, by the way other brand like asus, aoc, benq, acer also such good brand. aoc could be your other budget option, but i don't really like their 1080p monitor offering because of some of the monitors don't have vesa mounting, or sometimes the lack of option display input, meanwhile lg got such complete input for the same price
will get an 20" BenQ GL2070 priced at 70$ has vga and dvi inputs, 1600 X 900 Resolution as well as vesa mounting.
can the igpu handle the monitor though?
thanks for the info. :)
You sure to get 1600x900 monitor not 1920x1080 monitor? 1080p screen have such noticeable sharpness for sure. Also you sure you are fine with vga and dvi only? I would personally get at least the one with hdmi as it is such a more common display plug you found nowadays, then vga is still analog which might output bad color on several monitors
yup. will use dvi on the monitor as my main pc screen, then save up for another big screen for watching movies. it is still digital right? and i will still see if i can buy a gtx1050 next month. :)
ok then, by the way you know that benq monitor is using tn panel right? movies for sure will looks better in ips panel due to it better color reproduction, so maybe consider ips panel/other nearly identical kind of panel in your next purchase. dvi is indeed digital. graphics card price is still unstable so far, so if you got such a good deal on pricing, get it asap, also the 1050 ti might be more worth it, but it is up to you as i don't know your budget limit and preference
ok got it, a 20" ips led monitor. 🙂 🙂 budget is around 100$+ for medium and for good movies. :) :) :)
i personally got a 21.5" lg monitor for like $130 ish(not sure about the price convertion lol), i got that monitor really lucky, because other people sell it for $150 ish lol. by the way i guess 20" is kinda strange for an ips monitor, it is fhd right? usually fhd monitor start at 21 inch i guess lol, just saying.
