Hey, I am a first time builder residing in Trinidad and Tobago (Caribbean) and looking to get the right PSU to power my build: https://pcpartpicker.com/user/EliJoe868/saved/#view=xBTx6h
My build would be used for daily Photoshop/Illustrator usage, light Adobe Premier usage and gaming ever so often (CS:GO, PES, Skyrim, GTAV etc) I will be getting a GPU in the future Radeon RX 580, so factoring for that with regard to psu is also necessary.
I have been searching through forums for months and finally bought a Ryzen 3 2200g cpu (as it best fit my budget and came with the onboard graphics), will be purchasing an ASrock b450m Pro4 board month's end.
I am ordering everything from Amazon as my country has severely outdated or odd branded cpus, motherboards and gpus for purchase.
Budget for psu is between $50-$80USD as the conversion is almost $7TTD to $1USD. So trying not to go too overboard as custom fees are also to be factored in. All in all, I want to have a decent system and wouldn't want to purchase anything that can ruin that.
If you are wondering why I don't buy a psu locally, they carry brands like Agiler, Xtech, Imexx and ones with no branding. They are also very cheap (appox. $16-20USD) with high Wattage (600-1000w) ...i find that quite suspect, so I am avoiding that route. And there are stores that carry most of the EVGA psus that I have found one should avoid. So any help is welcomed! So far I am looking at the https://www.amazon.com/gp/product/B07MWHYQRC/ref=ox_sc_saved_title_1?smid=ATVPDKIKX0DER&psc=1
but I believe I will have to upgrade when I get the gpu which is what I am trying to not do.
Thanks in advance everyone and sorry for the paragraph, just want to give as much info as possible.
P.S. Also any advice regarding the best RAM is also welcomed. I am still checking through the ASrock QVL regarding that but whatever you think is best, I will look toward. I am thinking 16gb would be good due to the programs I want to run, is that ok?
