Best build with gtx 970 with max budget 900$?
SAK12
14
Consider: 1TB HDD,8 GB RAM,PSU,MOTHERBOARD,PROCESSOR(INTEL), CABINET(CHEAP),MONITOR(1080p)
How I want money to be spent:
gpu>cpu>motherboard>ram>psu>cabinet
Please adjust monitor in between and if possible then please keep skylake as priority be it xeon or i series !
Thank you.
Thanks,btw does Intel's hyper threading helps in 3d softwares or rendering?
How do I ask them?
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($242.99 @ SuperBiiz)
Motherboard: Asus B85M-D PLUS Micro ATX LGA1150 Motherboard ($59.99 @ Newegg)
Memory: Mushkin Stealth 16GB (2 x 8GB) DDR3-1600 Memory ($59.99 @ Newegg)
Storage: Mushkin Chronos 480GB 2.5" Solid State Drive ($119.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.99 @ SuperBiiz)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card ($282.99 @ NCIX US)
Case: Rosewill Galaxy-01 ATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: Rosewill 600W 80+ Gold Certified ATX Power Supply ($49.99 @ Newegg)
Total: $901.92
Generated by PCPartPicker 2016-01-21 08:11 EST-0500
8 thread CPU, 16 GB ram, huge SSD and your 970.
Isn't skylake future proof bcz of ddr4 and 14nm architc. plus xeon also comes in skylake v5 ?
the skylake Xeons aren't cost effective yet due to the lack of good motherboards yet. AS Rock and Gigabyte have some coming out, but we have no information on pricing or when they'll actually be out yet.
"Futureproof" is a horrible illusion in computers. everything goes obsolete at the same rate.
the way to think about the haswell Xeons vs Skylake I5s is the Xeons perform only about 5-10% slower ...which translates to maybe 1-2 fps difference for the same card
Will there be really much difference in performance if I go with i5 because it doesn't has hyper threading tech?
Hyperthreading will definitely make rendering faster, but how much of it are you doing? You can still edit and render on an i5, it's just a little slower. Ideally, an i7 would be a better choice, but it's not in the budget along with a GTX 970 unless you go with a Xeon and cheaper motherboard. It's all about compromise unless you have an unlimited budget. Personally, I would rather have the better features on Z170 board and onboard graphics. Even though you won't probably need them, it's nice to have when you do. Don't let the base clock of the i5 6400 fool you, the TurboBoost clock goes up to 3.2 whenever you doing something that requires more processor power.
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor ($183.88 @ OutletPC)
Motherboard: Gigabyte GA-Z170-HD3P ATX LGA1151 Motherboard ($89.99 @ Micro Center)
Memory: Kingston FURY 8GB (2 x 4GB) DDR4-2666 Memory ($59.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.88 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB SSC ACX 2.0+ Video Card ($309.99 @ NCIX US)
Case: Corsair 200R ATX Mid Tower Case ($47.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ NCIX US)
Monitor: Asus VN248H-P 23.8" Monitor ($110.98 @ Newegg)
Total: $908.69
Generated by PCPartPicker 2016-01-21 10:21 EST-0500
that depends on what you're running. some games now still run in only 2 threads, but many, starting back with Battlefield 4
will take asd many threads as you can throw at them. GTA 5 will take 4 (plus 1-2 for windows), Battlefield 3/4 will use all 8, Fallout 4 will use up to 8, and its only going to be more normal - especially since both the XBox One and Playstation 4 use 8 AMD Jaguar X86 cores.
