Best card w/out 6 pin connector
krazycontraptions
19
Hi, I have a prebuilt with a PCI-E port with no 6 pin power connector for the graphics card. I plan to play games suck as Battlefront 2 at max settings on a 1080p monitor, and I’m trying to find the best card that doesn’t require a 6 pin power cable. I’ve only found a GTX 1050 ti. Does anyone know if there is anything better that doesn’t require the extra power connector? Thanks
Some games will need to lower settings to maintain 60 fps, the 1050Ti is good for medium/high in demanding titles but will max out older games and less demanding ones. Not all games need 60 fps to play though, depends on the type of game and the drop in quality to high or medium settings if often not that bad - can still look better than consoles often times.
You will not find a better card that doesn't need a power connector though so if that's what you need this is the best you will do.
Thanks. And will it be able to run the newest titles at max settings with at least 60 fps?
Operating System
Windows 10 Home 64-bit
CPU
Intel Core i5 6400 @ 2.70GHz 52 °C
Skylake 14nm Technology
RAM
8.00GB Single-Channel Unknown @ 1064MHz (15-15-15-36)
Motherboard
LENOVO SKYBAY (U3E1)
Graphics
2269W (1920x1080@60Hz)
2047MB NVIDIA GeForce GT 730 (Unknown) 39 °C
Storage
931GB Seagate ST1000DX001-SSHD-8GB (SATA) 35 °C
14GB SDHC Card (USB)
Optical Drives
HL-DT-ST DVD-RAM GHC0N
Audio
Razer Surround Audio Controller
