I am looking for two 120mm fan dust filters for the intake on my antec 900 case, as it attracts dust easily. The front LED fans are the ones I need filters for. The fans are apparently called TriCool, if that makes any difference. Here is a picture
I know you're looking for a dust filter and I am not sure if this would be a help but I suggest you also buy a dust cover as an additional protection of your PC particularly your tower. Having a dust cover is one of the many preventive ways in protecting your tower against dust, moisture and spills.Hope you can find a 120mm fan dust filters.. 🙂
Basically any 120mm dust filter is ok for those fans. I own the same case and installed the Silverstone SST-FF123B 120mm dust filter. There are many manufacturers that make this stuff. Or you can go with the cheaper solution, just use used pantyhose (No, i'm not kidding, the material makes a great dust filter, it's just more difficult to install it, but you can manage)
