Best case fan for under $20
blacklex
147
Hey guys, as you can see in the title, I want some new case fans. I really wish I could get something under 25dba and a good CFM but since I have no experience with fans, I was wondering if you could help me out. I want some quiet and good quality fans but I don't want to make the mistake of getting the wrong kind.
andrei65
1,330
119
If noise is not a problem ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16835213012&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
If you buy it make sure you don't put your fingers on the fans while it's running , it could cut your fingers
At full load it sounds like a vaccum
But if you want it to be under 25dBa
http://pcpartpicker.com/part/bitfenix-case-fan-bff
Silverstone AP123 fans are pretty good and are very quiet. Use them for intakes if you have drive cages that could potentially block airflow. They are $18 http://www.newegg.com/Product/Product.aspx?Item=N82E16835220059&cm_re=ap123-_-35-220-059-_-Product
Corsair AF120 Quiet edition fans are pretty good and decently quiet. They are $18 http://www.newegg.com/Product/Product.aspx?Item=N82E16835181020&cm_re=corsair_af120-_-35-181-020-_-Product
The best fan would be the Noctua NF-S12A. It is extremely quiet and moves a lot of air. They also have a 7 or 6 ( I forget which) year warranty. They are $22
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608038&cm_re=noctua_nf-_-35-608-038-_-Product
Dark Lord of Tech
темный лорд технологий
http://www.newegg.com/Product/Product.aspx?Item=N82E16835129069&cm_re=AeroCool_DS-_-35-129-069-_-Product
Aerocool Dead Silent Fans
120mm
1500 RPM+/-10% (12V)
1100 RPM+/-10% (7V) 81.5 CFM (138.1 m³/h) (12V)
62.5 CFM (105.9 m³/h) (7V)
Fluid Dynamic
23.1dBA (12V)
14.8 dBA (7V)
